14 years ago
Nios II IDE
Sir,
i hv created a SOPC design using nios II (s) , jtag, sdram,pio,timer,sysid using Quartus 7.2 and trying to run hello program on this design using Nios IDE 7.2 . Build is successful, however running the program gives Launching->Error starting process . Same problem is encountered with Quartus 8.0. Kindly give solution to eliminate this problem.
using CycloneII EP2C35F672C6ES Altera's DE2 board
thnks
    Sir
    i am trying Nios II Hello program on the said SOPC builder setup and using CycloneII device
    1.device not available in main tab
    2.Refreshed jtag cable and jtag device (EP2C35 ) in Target connection tab
    problem not solved:(
    plz help
    Hi there,
    if there's no device recognized in the main tab, how did u come to refresh the connection?
    First create device:
    Go back to Run Configuration...
    Select Nios II Hardware
    Click on "New launch configuration" (the icon looks like a blank paper with a plus on it)
    Then you define a project name and choose your .elf while, which you build.
    After that it should run
    Sir,
    refresh connection available in the Target connection tab
    i think i hv selected whatever u said
    In Run Dialog box
    LHS i select NiosII Hardware, rt click, i get New/Duplicate/Delete
    click New , i get hello_world_small1_Nios II hw configuration
    RHS i get
    Main tab---- project:hello_world_small1
    NiosII elf : Release/hello_world_small1.elf
    ptf file : C:\altera\72sp3\quartus\rt\sysrt.ptf
    In Target Connection tab----
    jtag cable: USB-Blaster 0
    jtag device: (EP2C35 )
    Nios II commn device:jtag_uart(stdin/stdout/stderr)
    Sir,
    problem was with pin assignment .csv file
    error resolved:)
    glad to hear you fixed your problem.
    Could you provide a detailed description on how you fixed the error, so that other users facing similar problems could get some help here.
    Have a nice week end
    The names of the input and output pins in the .bdf file
    were matched with the .csv file pin names
    and compiled!
    Simple problem but took time to detect since i had used the software after
    a gap of about one year
    Regards ,
