14 years agoNios II IDE
Sir, i hv created a SOPC design using nios II (s) , jtag, sdram,pio,timer,sysid using Quartus 7.2 and trying to run hello program on this design using Nios IDE 7.2 . Build is successful, however ...
14 years agoHi there,
if there's no device recognized in the main tab, how did u come to refresh the connection? First create device: Go back to Run Configuration... Select Nios II Hardware Click on "New launch configuration" (the icon looks like a blank paper with a plus on it) Then you define a project name and choose your .elf while, which you build. After that it should run
