Rainwang
Contributor
2 years agoNios II Eclipse report error when run the mem_init_generate command
i am working on a project with a Nios II inside C4 FPGA, which uses on chip memory as the RAM. so after i build the project, i still need to run make targets-->Build -->mem_init_generate to generate...
- 2 years ago
Hi
Could you try adding a new environment variable below :
Value: SOPC_KIT_NIOS2/p
Jingyang, Teh
tehjingy_Altera
2 years agoHi
Just curious did you installed the required packages in the linux distribution?
If you have done that, then could you try launching the eclipse ide with administrator privilege?
Jingyang, Teh
- Rainwang2 years ago
Contributor
I checked my installation per the link you provided, all steps were done.
1. windows version: 22H2 19045.4651
2. WSL 1 and Ubuntu 18.04 installed.
3. windows subsystem for linux option turned on.
4. After reset PC, below commands were run.
sudo apt update
sudo apt install wsl
sudo apt install dos2unix
sudo apt install make
sudo apt install build-essential
5. try to generate the HEX file, still the same error appears.
6. open the Nios II EDS with administrator privilege, also the same error as below:
15:13:50 **** Build of configuration Nios II for project OTS_power_assist ****wsl make mem_init_generateInfo: Building /mnt/c/myproject/force_assist/G4_force_assisted_OTS_FPGA/01_project/software/OTS_power_assist_bsp/make --no-print-directory -C /mnt/c/myproject/force_assist/G4_force_assisted_OTS_FPGA/01_project/software/OTS_power_assist_bsp/[BSP build complete]Post-processing to create mem_init/program_ram.hex...elf2hex.exe OTS_power_assist.elf 0x00020000 0x0002bfff --width=32 --little-endian-mem --create-lanes=0 mem_init/program_ram.hexPost-processing to create mem_init/hdl_sim/program_ram.dat...elf2dat --infile=OTS_power_assist.elf --outfile=mem_init/hdl_sim/program_ram.dat \--base=0x00020000 --end=0x0002bfff --width=32 \--little-endian-mem --create-lanes=0/mnt/c/intelFPGA/21.1/nios2eds/bin/elf2dat: 2: .: Can't open /bin/sh_pl.shmake: *** [mem_init/hdl_sim/program_ram.dat] Error 2/mnt/c/myproject/force_assist/G4_force_assisted_OTS_FPGA/01_project/software/OTS_power_assist_bsp/mem_init.mk:301: recipe for target 'mem_init/hdl_sim/program_ram.dat' failed15:13:52 Build Finished (took 1s.345ms)thanks and regards,
Rain
