Rainwang
Contributor
2 years agoNios II Eclipse report error when run the mem_init_generate command
i am working on a project with a Nios II inside C4 FPGA, which uses on chip memory as the RAM. so after i build the project, i still need to run make targets-->Build -->mem_init_generate to generate...
- 2 years ago
Hi
Could you try adding a new environment variable below :
Value: SOPC_KIT_NIOS2/p
Jingyang, Teh
tehjingy_Altera
2 years agoHi
Could you check the WSL version that you are using currently?
It should be WSL version 1.
"wsl -l -v" To check the version
"wsl --set-version <ubuntu version> 1" to set version.
Jingyang, Teh
Rainwang
Contributor
2 years agohi, Jingyang,
I am very sorry to send response to you so late because I was on vacation in past 2 weeks and can't acess the E-mail.
i just checked my WSL version, it is version 1. please see the attachment and give me more comments.
thank you for the strong support.
Rain
