Rainwang's avatar
Rainwang
2 years ago
Nios II Eclipse report error when run the mem_init_generate command
i am working on a project with a Nios II inside C4 FPGA, which uses on chip memory as the RAM. so after i build the project, i still need to run make targets-->Build -->mem_init_generate to generate...
  • tehjingy_Altera's avatar
    2 years ago
    Hi
    Could you try adding a new environment variable below :
    Value: SOPC_KIT_NIOS2/p
    Jingyang, Teh
