Rainwang
Contributor
2 years agoNios II Eclipse report error when run the mem_init_generate command
i am working on a project with a Nios II inside C4 FPGA, which uses on chip memory as the RAM. so after i build the project, i still need to run make targets-->Build -->mem_init_generate to generate...
- 2 years ago
Hi
Could you try adding a new environment variable below :
Value: SOPC_KIT_NIOS2/p
Jingyang, Teh
tehjingy_Altera
2 years agoHi
Any update on this case?
Jingyang, Teh
