14 years agoNios II Debugger problem
When I try to debug the simple_socket_server app in Nios II SBT for Eclipse I get the following error: .gdbinit: No such file or directory. Reading symbols from C:/NEEK_Qsys/Ethernet3/neek_et...
14 years ago --- Quote Start --- Hmm, so without the debugger your code does not reset? That is interesting... I'll try different debug levels and also removing the debugger on monday! :) --- Quote End --- Yes, my code runs fine without the debugger. This is a custom board on which I have the Cyclone III FPGA logic being booted from an EPCS16 and the Nios II code booting from external flash memory. I just got the whole thing up and running with the Interniche NicheStack running both telnet and FTP services, both of which are interfaces to an on-board SD Card socket. Quite a chore, I must say... Good luck with your system on Monday.
