14 years agoNios II Debugger problem
When I try to debug the simple_socket_server app in Nios II SBT for Eclipse I get the following error: .gdbinit: No such file or directory. Reading symbols from C:/NEEK_Qsys/Ethernet3/neek_et...
14 years agoThis is getting way out of my area of expertise. Perhaps someone else on the forum will chime in with more info.
I'm thinking your problem may be an issue with Eclipse rather than your design. I found this entry in the eclipse.org forum, which may shed some light on your situation: http://www.eclipse.org/forums/index.php/m/503935/ Good luck...
