14 years agoNios II Debugger problem
When I try to debug the simple_socket_server app in Nios II SBT for Eclipse I get the following error: .gdbinit: No such file or directory. Reading symbols from C:/NEEK_Qsys/Ethernet3/neek_et...
14 years agoThanks for the suggestion, but there was no change..
The problem is still there even if the the debugger is not in use, but in that case the cpu just hangs. With the debugger I get the error msg and it resets.
