14 years agoNios II Debugger problem
When I try to debug the simple_socket_server app in Nios II SBT for Eclipse I get the following error: .gdbinit: No such file or directory. Reading symbols from C:/NEEK_Qsys/Ethernet3/neek_et...
14 years agoTry running Nios II Software Build Tools for Eclipse "as administrator" to see if that helps.
In Windows Start Menu, click on All Programs, then open the Altera folder. Select Nios II EDS 11.0sp1 (or whichever version you are running) then right-click on nios iisoftware build tools for eclipse and select run as administrator. Windows will probably ask you if this is OK, just say yes. The SBT will now have administrative privileges so sharing files will not be an issue. Good luck!
