Nios II Command Shell doesn't work backspace Key
i found it my self..
that's Problem TERM environment
Anyone who has this problem, try to this code
> echo $TERM
nutc
export TERM=cygwin
for me, "nutc" ..
i don't know what's Type of Terminal.
i found some terminals... or you can try to "cygwin"
ansi, dtterm, nsterm, rxvt, vt52, vt100, vt102, xterm, xterm-16color and xterm-256color,
Hi @jjang,
Thank you for posting in Intel community forum and appreciate your effort as well as sharing the solution.
Seem that the environment variable for are being setup as another type of terminal.
Usually if you are running in Windows and installed WSL, at least for me the terminal that comes with it would be 'xterm-256color'.
For our references what OS and quartus version are you running on?
Warm regards.
BB
