13 years agoNios II boot Remote Update
I'm working on the Nios II with the device cyclone III, my flash EPCS64 memory contains 2 FPGA images and 2 softwares. The 1st FPGA image (factory) address is 0, the 1st Nios software address is ...
13 years agoThank you for you answer.
It works !!! I had 2 problems: - I was using an onchip ROM instead of RAM to store the bootloader in SOPC - Then I have seen after reading back EPCS content that Nios binary file must be written without any byte modification unlike RBF files. So I have modified the ROM to RAM and the way I write nios file on EPCS and now everything is working. Now Nios can boot from a custom offset in EPCS and I can update binary file in EPCS !!
