13 years agoNios II boot Remote Update
I'm working on the Nios II with the device cyclone III, my flash EPCS64 memory contains 2 FPGA images and 2 softwares. The 1st FPGA image (factory) address is 0, the 1st Nios software address is ...
13 years agoI used this method from altera wiki and it worked,
but I did with another way, I modified boot_loader_epcs_bits_sii_siii_ciii.S directly from : D:\altera\10.1sp1\nios2eds\components\altera_nios2\boot_loader_sources. If you want in the following zip follow the instructions in info.txt to generate a new EPCS bootloader with the file .bat (maybe you'll have to change the path in this .bat with yours)
