13 years agoNios II boot Remote Update
I'm working on the Nios II with the device cyclone III, my flash EPCS64 memory contains 2 FPGA images and 2 softwares. The 1st FPGA image (factory) address is 0, the 1st Nios software address is ...
13 years agoHi,
aha you meant the alt_alarm mechanism. I thought from your post, that you found the solution, that you have to reset the watchdog periodically in that data sheet But thanks anyway. But there have to be a way to stop that watchdog, that's not really a practical solution. BTW: On alt_alarm usage: The function which calls alt_alarm also increments the ntick counter, which you can read by alt_nticks(), this counter does not count up as long as the alt_alarm callback function is running. I had this problem when i tried to measure system time with this alt_ntick and saw it driftign away. So just keep that in mind.
