naand
2 years agoNIOS II - FW doesn't work with compiler optimization turned on
Dear support team, I have a problem with the behavior of the firmware if the project is built in release mode with optimization enabled. The problem occurs during the write-to-flash routine. I u...
wwanalim_intel
Contributor
2 years agoHi,
Sorry for not updating as I just got back from long holiday.
Will check with engineering team on the step if the optimization can be disable for a specific block of code.
Thank you.
