naand
2 years agoNIOS II - FW doesn't work with compiler optimization turned on
Dear support team, I have a problem with the behavior of the firmware if the project is built in release mode with optimization enabled. The problem occurs during the write-to-flash routine. I u...
wwanalim_intel
Contributor
2 years agoHi,
I am checking this issue with internal teams.
In the meantime, can you provide the project file as I want to try and monitor the detail of the issue on my side.
- naand2 years ago
Hi,I cannot share the project files. This is a complete project with corporate know-how, and I cannot share it entirely (I could share only small portions).Also, the project is not based on a dev board, but on custom hardware, so I don't know how the code can be tried.Thank you.Regards,naand
