19 years agoNios custom component I/0 problem in DE2
Hi all,
I have added a simple component using SOPC Builder. The signals of the component are as follows Port (
clk : in std_logic;
reset : in std_logic;
cs : in std_logic;
wr : in std_logic;
din : in std_logic_vector(31 downto 0);
rd : in std_logic;
dout : out std_logic_vector(31 downto 0) ); I assigned clk and reset to global signals clk and reset. cs, wr, din are assigned to chipselect, write and writedata of avalon_slave_0 interface and rd, dout to read and readdata signals of avalon_slave_1 interface. I perform input when cs and wr are high. But i find that cs and wr are never going high. I use following code to perform input and output. en <= cs and wr;
--Process for Input and output
process ( en, clk, reset)
begin
if (reset = '1') then
data_in <= (others => '0');
elsif (clk'event and clk='0') then
if ( en = '1') then
data_in <= din;
end if;
dount <= data_in;
end I access the custom logic using a C program. I run uClinux on the top of Nios processor. My C application runs on uClinux. My C program is very simple and just writes and reads the data. Program is shown below main()
int *p,*u;
int i,k=0;
p = 0x0090002C;
u = 0x00900098;
for ( i = 0; i < 10000; i++ )
*p = i;
printf(" \n Data_out: %x ", *u);
} the same setup was working on stratix1s10 board. But it is not working on DE2 board. I tried read and write wait cycles of 0 and 1 for avalon interface. I tried sampling on negitive edge and also tried on positive edge. Nothing is working. Can anyone help me.2 Replies
I am sorry. I forgot to set the uncache bit. Now everything is working fine. sorry for the post. Regards, Mythri. --- Quote Start --- originally posted by mythri@Nov 4 2006, 06:18 PM hi all,i have added a simple component using sopc builder. the signals of the component are as follows
port ( clk : in std_logic; reset : in std_logic; cs : in std_logic; wr : in std_logic; din : in std_logic_vector(31 downto 0); rd : in std_logic; dout : out std_logic_vector(31 downto 0) );i assigned clk and reset to global signals clk and reset.
i perform input when cs and wr are high. but i find that cs and wr are never going high. i use following code to perform input and output.
en <= cs and wr; --process for input and output process ( en, clk, reset) begin if (reset = '1') then data_in <= (others => '0'); elsif (clk'event and clk='0') then if ( en = '1') then data_in <= din; end if; dount <= data_in; endi access the custom logic using a c program. i run uclinux on the top of nios processor. my c application runs on uclinux. my c program is very simple and just writes and reads the data. program is shown below
main() { int *p,*u; int i,k=0; p = 0x0090002c; u = 0x00900098; for ( i = 0; i < 10000; i++ ) { *p = i; printf(" \n data_out: %x ", *u); } }the same setup was working on stratix1s10 board. but it is not working on de2 board. i tried read and write wait cycles of 0 and 1 for avalon interface. i tried sampling on negitive edge and also tried on positive edge. nothing is working.
can anyone help me.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=19160)</div> --- Quote End ---
--- Quote Start --- originally posted by mythri@Nov 4 2006, 08:48 AM hi all,i have added a simple component using sopc builder. the signals of the component are as follows
can anyone help me.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=19160)</div> --- Quote End --- Hi,mythri I'm Nios Newbie. I want added a simple component using SOPC Builder. Can you give me a complete simple example? thanks. Regards faye
