14 years ago
Nios 2 to custom component communication
I'd like to know what instructions of Nios C program Do I need for writing and reading data to/from a custom component of sopc system???
I saw in some AN people use IORD() /IOWR() macros or printf() function....Is it correct???
bye
    The timing depends from a number of factors:
    - actual device and speed grade
    - system clock frequency
    - synthesis result
    - placement inside fpga
    Then you have different timing even for the very same design.
    I tried to program the simple socket server example .sof file doing test using nios2 according to example application explanation...and It works properly....even if there are these critical warnings...Why does it work the same???
    Timequest studies the worst case scenarios. Even with those critical warnings, you could still get a system that works perfectly at ambient temperature, but will start failing it higher temperatures, for example.
