15 years agoNIOS + IRQ + custom component
Hi, I'm trying to interrupt a Nios Prosessor whit a Custom Component and setup a successful interrupt routine. But I can't Do it.
The problem is that i can't find a complete example of a custom component connected to a NIOS II processor who succesfuly call a ISR. Can someone help me? Jairo34 Replies
I would start by reading through this section of the handbook and practicing using an input PIO as an interrupt source:
http://www.altera.com/literature/hb/nios2/n2sw_nii52006.pdf If you need additional help shoot me a pm with your email address and I'll send you a test design that contains a random IRQ generator I created a while back for reasons I can't really remember :) - Altera_Forum
Tks, BadOmen, I am reading.
I can't PM, but you can email the example to frodobolsonxx (at) gmail (dot) com Tks again jairo - Altera_Forum
I would appreciate a copy of the example SOPC custom component with IRQ , if available. please send to: kered95 at gmail dot com Thanks. - Altera_Forum
Ok it's sent.
Thanks BadOmen,
Much appreciated. Ken. :) - Altera_Forum
Please send the example SOPC custom component with IRQ to rgjokerit at gmail dot com. Thanks. - Altera_Forum
Please send the example SOPC custom component with IRQ to alexandrvb58 at gmail dot com. Thanks. - Altera_Forum
Seems to me that you should be doing your own assignments.
Remember your tutor will also be reading the forum! - Altera_Forum
Sent. <post needs 10+ characters so this is to make the forum happy>
Hi, now I'm also trying to interrupt the CPU with my custom component.
So my custom component consists of this following blocks : 1. FIFO, this FIFO receives input from outside SOPC and send the output to DMA 2. Write_control, to control how the FIFO writes its data After a certain number of data (for example 10) have been written in the FIFO, the FIFO should send an interrupt signal to CPU. I've provided an irq signal (the interface type is 'interrupt sender', the interrupt signal's width is one clock) and connected it to the CPU's interrupt receiver interface. My question is in the interrupt sender properties, which Avalon MM slave that I have to assign? Is it the Avalon MM slave of the FIFO output data interface? I've tried to assign the Avalon MM slave of the FIFO output data in the interrupt sender properties. I also have written the interrupt handler C code like shown in Quartus manual. However my design didn't work. Does anyone have any suggestion for me? Thank you
