20 years agoNFS share
I'm trying to setup an NFS share on the 1c12 dev board. I add into kernel : <div class='quotetop'>QUOTE </div> --- Quote Start --- File system --> Network FS --> [*] NFS file system support [*] provide NFSV3 client support [*] NFS server support [*] provide NFSV3 server support [*] provide NFS server over IP[/b] --- Quote End --- I want a network share named flashfs which is a /flashfs directory.# mount -t nfs 172.16.207.43:/flashfs /flashfs -n -o nolock I've got the error <div class='quotetop'>QUOTE </div> --- Quote Start --- mount: RPC: Port mapper failure - RPC: Unable to receive[/b] --- Quote End --- In case I built uClinux portmap but when executing I've got the error <div class='quotetop'>QUOTE </div> --- Quote Start --- portmap: fork: Function not implemented[/b] --- Quote End --- What am I missing? Please help Thks Marc2 Replies
This is NFS server, do you let the target Nios2 board to provide NFS server? So it is not nessary to enable them. Second,the mount command excued in Nios2 board is:NFS server support provide NFSV3 server support provide NFS server over IP
/home/nfs is a dir which your host linux should share it by NFS server. /usr/bin is the mount point for Nios2 target to accessmount -t nfs 218.192.171.46:/home/nfs /usr/bin -n -o nolock - Altera_Forum
Thank you very much for your help
Marc
