20 years agoNFS share
Hi, I'm trying to setup an NFS share on the 1c12 dev board. I add into kernel : <div class='quotetop'>QUOTE </div> --- Quote Start --- File system --> Network FS --> [*] NFS...
20 years ago NFS server support
provide NFSV3 server support
provide NFS server over IP This is NFS server, do you let the target Nios2 board to provide NFS server? So it is not nessary to enable them. Second,the mount command excued in Nios2 board is: mount -t nfs 218.192.171.46:/home/nfs /usr/bin -n -o nolock /home/nfs is a dir which your host linux should share it by NFS server. /usr/bin is the mount point for Nios2 target to access
