20 years agoNewbies problem with DMA
I've started a new project based upon an older without SOPC/NIOS II, that means i have an already existing AHDL component reading data from a CMOS chip.
My problem is now to get this data into the NIOS II cpu. At the moment, I save this data in an altsyncram outside SOPC and connect via avalon slave interface (Avalon slave template without write-signals, 0 read waitcycles, 2 read latencies). Then in the software I wait for a signal "data available" (polling PIO) and start DMA transfer. But the time between getting the "data available" signal and the real DMA transfer is 2 µs (measured with PIO-outputs and scope), that means alt_dma_txchan_send() and alt_dma_rxchan_prepare() need 2 µs to execute? I get every 4.4µs a new data packet, so 2 µs for starting DMA transfer is too long. After the DMA transfer there are 2µs until my receive callback function is called, but that's not so important. I'm afraid, that I have the wrong approach to the problem. How can I shorten the time to start DMA? Or better, how can I feed my data directly into DMA? I did not found any examples for that. Thanks in advance! Environment: DSP Development Board Stratix II EP2S60 Quartus and NIOS V 5.1, NIOS fast core1 Reply
A moment ago I realized, that I don't need the DMA transfer to have fast access to the data, but I can read data directly.
Please forget my question and sorry for that! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/unsure.gif
