21 years agoMultiprocessor system problem
Hi everybody,
I've designed a multiprocessor system with two Nios II, f ans s type.I have various peripherals and in particular there is a uart shared between the CPUs. This is the problem: a simple program is running in both the processors and when any processors sends a character to the uart, the system crashes. any suggestions?3 Replies
You can only connect a UART to one processor. See previous messages on this forum.
Think about what happens when an interrupt occurs for why this won't work. - Altera_Forum
Hi wombat,
thank u for the suggestion. I understand the problem with the interupt, but could this happen even if the uart interupt of one processor is disabled? - Altera_Forum
If you connect the UART interrupt to only one processor then there will probably be slightly different confusion (its a long time since I looked at the UART code).
If any characters get transmitted at all from the other processor then there may well be some data loss
