21 years agoMultiprocessor system problem
Hi everybody, I've designed a multiprocessor system with two Nios II, f ans s type.I have various peripherals and in particular there is a uart shared between the CPUs. This is the problem: a ...
21 years agoIf you connect the UART interrupt to only one processor then there will probably be slightly different confusion (its a long time since I looked at the UART code).
If any characters get transmitted at all from the other processor then there may well be some data loss
