JoshuaWillson
3 years agoMultiple NIOS V Implementation
Hi, I was looking at the NIOS V Processor Reference Manual. I could not find the max instantiations you can implement on a FPGA. I see many designs online of Nios II Multiprocessors. Can I make the ...
- 3 years ago
Unfortunately, the official support for Nios V to use Mutex HAL API is not yet supported.
You may implement them at your own accord and we may not be able to support further if you encounter issue.
With this, do you have any further questions?
Again, we apologies giving you this bad news.
PShar32
5 months agoI am thinking of :
- Compile the niosV codes in ashling.
- Generate .hex files for all the nios V processors.
- in platform designer , initialize the on-chip memory of NiosV with the hex file.
- Compile the Qsys.
- Compile the Quartus project.
- Dump the .sof file.
Will this work,.. ?
SueC_Altera
Contributor
5 months agoDoes this guidance help?
not able to use multiple niosV cores at the same time | Altera Community - 354487
Sue
