13 years ago
Multiple Nios II and Qsys
Is there anybody that used/have experience with Qsys to fit five Nios II on a Cyclone IV EP4CE22 FPGA?
I could only fit one. I need to use SDRAM controller.
I'd like to know how many Nios II have ever fit on 22,300 Logic Elements.
Alan
    I have my SDRAM at 0x80_0000.
    1st Core: Reset Vector: 0x80_0000
    Exception Vector: 0x80_0020
    2nd Core: Reset Vector: 0x81_0000
    Exception Vector: 0x81_0020
    3rd Core: Reset Vector: 0x82_0000
    Exception Vector: 0x82_0020
    4th Core: Reset Vector: 0x83_0000
    Exception Vector: 0x83_0020.
    Though when I run my 1st core, it runs & says "starting at address 0x80_0020".
    But when I run my 2nd core, it freezes the 1st core and itself runs in a weird way and says "starting at address 0x80_0000".
    Can anyone please suggest why 2nd core is starting to run at 0x80_0020. It should start at 0x81_0020.
    It could be a problem in your link script. Check that the application for the second core is indeed mapped in the 0x81xxxx range in the link script. Did you create separate link sections for all 4 cores?
    It looks okay to me. You can always try and run the nm command on the generated elf files to check that everything is put in the correct memory area, but I don't see any problem in your linker script settings.
    My next suggestion would be to put some signaltap probes around the two CPU's Avalon masters to try and figure out what they are doing and why your first CPU is freezing.
