14 years agomulticycle custom instruction not working
Hi All, I am trying a 3 cycle (fixed) multi cycle instruction module with nios2. below s my interface. port ( clk : in std_logic := '0'...
13 years agoI have the same problem. Same logic works when i implemented it as combinational, but since it has limitations i have to use multicycle custom instructions, however I couldn't get the correct result after running the project. In the Quartus ii timing simulation it shows the correct result after 4 cycles.
Thanks in advance for any support that you could provide.
