16 years ago
mounting SD Card on uClinux
Hi everyone,
I'm trying to implement a fat file system on sd card
I followed the instructions for Altera SPI Core on this page
http://www.nioswiki.com/operatingsystems/uclinux/mmcsd
didn't work...
was I suppose to use SPI (3 wire) IP?
thanks,
Asaf
    --- Quote Start ---
    Have you edited your dts file with mmc-spi-slot? See section 3.2 in my uClinux_nios2.pdf document.
    --- Quote End ---
    Hi, Thanks for your respond. I got it to work and thanks to Alex Hornung.
    Problem:
    1) device tree
    spi_0: spi@0x140 {
    compatible = "ALTR,spi-altera_avalon_spi", "ALTR,spi-1.0";
    reg = < 0x00000140 0x00000020 >;
    interrupt-parent = < &myCPU >;
    interrupts = < 3 >;
    /*# address-cells = < 1 >; */ <-comment out
    /*# size-cells = < 0 >; */ <-comment out
    mmc-spi@0 { <- make sure is named mmc-spi
    compatible = "mmc-spi-slot";
    spi-max-frequency = < 10000000 >;
    reg = < 0x00000000 >;
    voltage-ranges = < 3300 3300 >; <-missing important piece
    }; //end mmc-slot@0
    }; //end spi@0x140 (mmc_spi)
    2) menuconfig - Make sure selection is [*] and not [M]
    3) of_mmc_spi.c <-there is a bug
    for (i = 0; i < num_ranges; i++) {
    const int j = i * 2;
    u32 mask;
    u32 vdd_min = be32_to_cpu(voltage_ranges[j]);
    u32 vdd_max = be32_to_cpu(voltage_ranges[j + 1]);
    mask = mmc_vddrange_to_ocrmask(voltage_ranges[j],
    mask = mmc_vddrange_to_ocrmask(vdd_min, vdd_max);
    if (!mask) {
    ret = -EINVAL;
    dev_err(dev, "OF: voltage-range# %d is invalid\n", i);
    goto err_ocr;
    oms->pdata.ocr_mask |= mask;
    Hi
    When i insert the SD card i get the below message and also can't mount the SD Card
    root:/dev> mmc0: SD Status: Invalid Allocation Unit size.
    mmc0: host does not support reading read-only switch. assuming write-enable.
    mmc0: new SD card on SPI
    mmcblk0: mmc0:0000 SD512 478 MiB
    mmcblk0: p1
    root:/dev> mount -t vfat /dev/mmcblk0 /mnt
    mount: mounting /dev/mmcblk0 on /mnt failed: No such device
    root:/dev> mount -t vfat /dev/mmcblk0p1 /mnt
    mount: mounting /dev/mmcblk0p1 on /mnt failed: No such device
    root:/dev>
    I also format the sdcard with FAT32 and 512byte but it doesn't help
    Please give me some suggestion to fix the problem
    It's a good sign if you see it detect the SD Card size. I am using a 2 GB SD Card so perhaps you may want to try a bigger size memory? Also, to make sure you enabled the [*] fat32 in file system doing kernel setup. I hope this help.
    --- Quote Start ---
    Hi
    mmcblk0: p1
    root:/dev>
    --- Quote End ---
    Hi, all.
    May be, it's too late to answer, but my message may help someone in the future and one question still left regarding this topic.
    --- Quote Start ---
    --- Quote End ---
    Well, next step is definitely simple:
    Lets look at the devices, configured in the system:
    /#  cat /proc/devices
    Character devices:
      1 mem
      2 pty
      3 ttyp
      4 ttyS
      5 /dev/tty
      5 /dev/console
      5 /dev/ptmx
     10 misc
    128 ptm
    136 pts
    153 spi
    204 ttyUL
    Block devices:
      1 ramdisk
    259 blkext
    179 mmc <--- Got it!
    OK, our MMC card is configured as block device and had major number 179.
    /#  ls /sys/dev/block/ | grep 179
    179:0
    179:1
    We see two devices with major = 179. The first one with minor number 0 is MMC (SD) card itself and the second with number 1 is the first (and last in my case) partition on the card.
    The problem is that "ls /dev/" command shows nothing about MMC, but we can make device node manually via mknod command:
    /#  mknod /dev/mmcblk0p1 b 179 1
    /#  mount /dev/mmcblk0p1 /mnt/
    /#  ls /mnt
    simpleImage.xilinx.ub  vmlinux
    Thats it!
    Well, but I still do not know, how to make next step: say system to create /dev/mmcblk0p1 node automatically and have root partition on my SD card during boot.
    Thanks all for this topic, it was helpful.
    PS: Well, there was almost nothing magic.
    On BB:
    1. Format your SD card in ext2 or ext3.
    2. Copy busybox content into SD
    3. (For paranoics like me :) ) Create static node /dev/mmcblk0p1 on SD using mknod with major:minor numbers 179:1
    4. [MAGIC] Edit kernel boot parameters with "root=/dev/mmcblk0p1" and (this is important!) "rootdelay=3".
    The "rootdelay" parameter says kernel to wait until root partition initialization complete. Three seconds was enough in my case. [/MAGIC]
    Thats all, folks. :)
    Hello i am trying to implement SDCard in my DE2-115 and i've followed the steps described in the# 6 post. However i get this error in the linux boot process spi_altera: pobe of d000900.spi failed with error -16.
    There appears to be a mmc in proc/devices though.
    Any ideas? Can i use the default clock frequency of SPI 3 wire? I think it's 128khz.
    Solved it! It was a problem with EPCS ADDRESS SPAM being too high, it was going in the SPI 3 wire address spam
    I feel like it's really slow to read/write in the SDCard. It's formated with FAT file system and my NIOS2 is running at 100mhz.
    Any tips?
