16 years agomounting SD Card on uClinux
Hi everyone, I'm trying to implement a fat file system on sd card I followed the instructions for Altera SPI Core on this page http://www.nioswiki.com/operatingsystems/uclinux/mmcsd didn't w...
16 years agoI want know why after I use nios2-terminal command, I cann't see the display messages above,is the hardware problem or pin assign problem?
"mmc0: host does not support reading read-only switch. assuming write-enable. mmc0: new SDHC card on SPI mmcblk0: mmc0:0000 SD04G 3.69 GiB mmcblk0:Command: mount -t proc proc /proc -o noexec,nosuid,nodev " DO you means that I should download the zImage and mmc_block.o and mmc_spi.o at first ?and modprobe mmc_block and mmc_spi ? I make zImage with mmc_block.o and mmc_spi.o. "nios2-linux/uClinux-dist/linux-2.6.x/drivers/mmc/host/mmc_spi.o" "nios2-linux/uClinux-dist/linux-2.6.x/drivers/mmc/card/mmc_block.o"
