20 years agomk_target_board
I have created a custom board with mk_target_board command as stated under: "Porting the Nios II Flash Programmer to Custom Boards" of the Nios II Flash Programmer User Guide - document version 1.1 CFI-Flash: AM29DL640D Target Board: Altera PCI Development Board, Stratix (EP1S25) I have specified: address size: 22 bits data size: 16 bits but the block diagram shows address size of 23 bits (address[22..0]). How can I correct this? Thanks3 Replies
If your 29DL640D flash is 16-bit data bus, just use CFI ADDR[1..22] to map to your flash device A[0..21]. Leave CFI ADDR[0] unused. LiangYi - Altera_Forum
--- Quote Start --- originally posted by liangyi@Oct 1 2005, 02:17 AM hi,if your 29dl640d flash is 16-bit data bus, just use cfi addr[1..22] to map to your flash device a[0..21]. leave cfi addr[0] unused.
liangyi
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=10083)
--- quote end ---
--- Quote End --- Thanks for your reply you mean leave cfi_addr[0] from the sopc generated block diagram unconnected? By the way, do you happen to know what is the setup, wait and hold time for this flash device? I have setup: 35 wait: 130 hold: 35 Thanks again
> You mean leave cfi_addr[0] from the sopc generated block diagram unconnected? Yes. > By the way, do you happen to know what is the setup, wait and hold time for this flash device? I think the default values are jusk OK. You can try. Regards, LiangYi
