20 years agomk_target_board
Hi, I have created a custom board with mk_target_board command as stated under: "Porting the Nios II Flash Programmer to Custom Boards" of the Nios II Flash Programmer User Guide - document v...
20 years agoHi,
> You mean leave cfi_addr[0] from the sopc generated block diagram unconnected? Yes. > By the way, do you happen to know what is the setup, wait and hold time for this flash device? I think the default values are jusk OK. You can try. Regards, LiangYi
