20 years agoMicrotrinix Linux Distribution 1.4
Microtrinix Linux Distribution 1.4 is giving problem -
After installing, the Microtronics option is not appearing in Nios II IDE-> New Projects Regards4 Replies
SOS!
I met the same problem! I reinstalled,but failed again.I can't find the reason. Please help me! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/huh.gif Thank you very much http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/rolleyes.gif --- Quote Start --- originally posted by rau@Jan 7 2006, 08:54 PM microtrinix linux distribution 1.4 is giving problem -after installing, the microtronics option is not appearing in
nios ii ide-> new projects
regards
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=12034)
--- quote end ---
--- Quote End ---
I have met the same problem. Because I used the evaluation edition of Nios II shipped with the board.
Try the full edition, you will find everything is fine. - Altera_Forum
--- Quote Start --- originally posted by lovelyboy@Jan 12 2006, 07:50 PM i have met the same problem. because i used the evaluation edition of nios ii shipped with the board.try the full edition, you will find everything is fine.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=12161)
--- quote end ---
--- Quote End --- Where can I find the full edition?
Better do it on Linux, it is easy.
http://forum.niosforum.com/forum/index.php?showtopic=3174 (http://forum.niosforum.com/forum/index.php?showtopic=3174)
