15 years agoMessage Q with Data Structure help
Good day. I am a little rusty on C so would like some basic help. I would like to define a structure to hold Character LCD data such as the text string, the position, and the style. I would like to use the structure to pass messages to the LCD display task which will then write to the LCD.
I have defined typedef struct message{ char text[16]; int xpos; int ypos; enum { STEADY, BLINK } textstyle; } LCDMessage LCDMessage LCDMessages[10]; Now what is the proper method of initializing the Q for MicroC because all the examples show the void type for pointer. So I'm guessing I need to map an array of pointers to the data structures but not sure. Can someone please straighten me out and show me a simple example using a structure for messages. Is this possible? Thanks JT2 Replies
I do it like this:
I used C++ therefore the bool type karsten# define L_CMD_BUFFER_SIZE 0x1000 // Only Hexnumbers like 0x10, 0x20 ...... # define L_MSG_QUEUE_MASK (L_CMD_BUFFER_SIZE - 1) ////////////////////////////////////////////////////////////////////////////////////////////////////////////////// LCDMessage m_t_msg_buffer; unsigned int m_ui_message_write_pointer; OS_EVENT * m_message_queue; ...... void init_message_system ( void ) { m_ui_message_write_pointer = 0; if(!(m_message_queue = OSQCreate(&m_CommMsg, L_CMD_BUFFER_SIZE))) { puts("OSQCreate() failed\r\n"); return; } } void send_message ( const LCDMessage * para_t_command ) { # if OS_CRITICAL_METHOD == 3 OS_CPU_SR cpu_sr; # endif OS_ENTER_CRITICAL(); memcpy(&m_t_cmd_buffer, para_t_command, sizeof(LCDMessage)); OS_EXIT_CRITICAL(); switch(OSQPost(m_message_queue, (void *)&m_t_cmd_buffer)) { case OS_NO_ERR: { break; } case OS_Q_FULL: { // error handling .... break; } case OS_ERR_EVENT_TYPE: { // error handling .... break; } case OS_ERR_PEVENT_NULL: { // error handling .... break; } case OS_ERR_POST_NULL_PTR: { // error handling .... break; } default: { // error handling .... break; } } OS_ENTER_CRITICAL(); m_ui_message_write_pointer = (m_ui_message_write_pointer + 1) & L_MSG_QUEUE_MASK; OS_EXIT_CRITICAL(); } bool get_message ( LCDMessage * para_ptr_command_buffer, INT16U para_ui_timeout ) { LCDMessage * proc_ptr_command; INT8U proc_os_error; # if OS_CRITICAL_METHOD == 3 OS_CPU_SR cpu_sr; # endif proc_ptr_command = (t_command_typ *)OSQPend(m_message_queue, para_ui_timeout, &proc_os_error); switch(proc_os_error) { case OS_NO_ERR: { OS_ENTER_CRITICAL(); memcpy(para_ptr_command_buffer, proc_ptr_command, sizeof(LCDMessage )); OS_EXIT_CRITICAL(); return(true); // msg received } case OS_TIMEOUT: { return(false); } case OS_ERR_EVENT_TYPE: { // error handling ... return(false); } case OS_ERR_PEVENT_NULL: { // error handling ... return(false); } case OS_ERR_PEND_ISR: { // error handling ... return(false); } default: { // error handling ... return(false); } } } - Altera_Forum
OS_EVENT * some_queue;
void* some_queue_tbl[16]; some_queue = OSQCreate(&some_queue_tbl[0], 16); task1 { OSQPost(some_queue, (void *)pointer_to_your_struct); } task2 { your_struct_type * pointer_to_my_struct_type; pointer_to_my_struct_type = (your_struct_type *)OSQPend(some_que, 0, &err); }
