15 years agoMessage Q with Data Structure help
Good day. I am a little rusty on C so would like some basic help. I would like to define a structure to hold Character LCD data such as the text string, the position, and the style. I would like to u...
15 years agoI do it like this:
# define L_CMD_BUFFER_SIZE 0x1000 // Only Hexnumbers like 0x10, 0x20 ......
# define L_MSG_QUEUE_MASK (L_CMD_BUFFER_SIZE - 1)
LCDMessage m_t_msg_buffer;
unsigned int m_ui_message_write_pointer;
OS_EVENT * m_message_queue;
void init_message_system
void
m_ui_message_write_pointer = 0;
if(!(m_message_queue = OSQCreate(&m_CommMsg,
L_CMD_BUFFER_SIZE)))
puts("OSQCreate() failed\r\n");
return;
void send_message
const LCDMessage * para_t_command
# if OS_CRITICAL_METHOD == 3
OS_CPU_SR cpu_sr;
# endif
OS_ENTER_CRITICAL();
memcpy(&m_t_cmd_buffer,
para_t_command,
sizeof(LCDMessage));
OS_EXIT_CRITICAL();
switch(OSQPost(m_message_queue,
(void *)&m_t_cmd_buffer))
case OS_NO_ERR:
break;
case OS_Q_FULL:
// error handling
break;
case OS_ERR_EVENT_TYPE:
// error handling
break;
case OS_ERR_PEVENT_NULL:
// error handling
break;
case OS_ERR_POST_NULL_PTR:
// error handling
break;
default:
// error handling
break;
m_ui_message_write_pointer = (m_ui_message_write_pointer + 1) & L_MSG_QUEUE_MASK;
OS_EXIT_CRITICAL();
bool get_message
LCDMessage * para_ptr_command_buffer,
INT16U para_ui_timeout
LCDMessage * proc_ptr_command;
INT8U proc_os_error;
OS_CPU_SR cpu_sr;
# endif
proc_ptr_command =
(t_command_typ *)OSQPend(m_message_queue,
para_ui_timeout,
&proc_os_error);
switch(proc_os_error)
case OS_NO_ERR:
memcpy(para_ptr_command_buffer,
proc_ptr_command,
sizeof(LCDMessage ));
OS_EXIT_CRITICAL();
return(true); // msg received
case OS_TIMEOUT:
return(false);
// error handling
return(false);
// error handling
return(false);
case OS_ERR_PEND_ISR:
// error handling
return(false);
default:
// error handling
return(false);
I used C++ therefore the bool type karsten
