max10 RSU without nios
hii
is there a documentation that show the work flow that i need in order to perform MAX10 rsu without the help of nios ii , with my discrete logic ???
- KalenB_Altera
Hi Aiebd,
RSU on Max 10 has two key steps; 1) Write the new image to flash via the User Flash Memory IP (https://www.intel.com/content/www/us/en/docs/programmable/683180/18-0/on-chip-flash-core-references.html) and 2) Identifying to the configuration system what CFM to use on the next nConfig and trigger reconfiguration via the Dual Configuration IP (https://www.intel.com/content/www/us/en/docs/programmable/683865/current/dual-configuration-core-26199.html).
You could definitely use an FSM to do these operations. I hope these user guides help give you the info you need.
- aiedb
hii thanks a lot for help
lets say i want to write my own fsm to trigger an rsu after writing my image to cfm0 and cfm 1/2 what are the registers that i need to work with in order to :
1- trigger the nconfig ?
2-to choose from which cfm that fpga get configured ?
- KalenB_Altera
Hi Aiebd,
Section 5.2 of the Dual Config IP mentions the registers and fields. Here's a link: https://www.intel.com/content/www/us/en/docs/programmable/683865/current/dual-configuration-core-memory-mapped.html
The relevant registers for your question are at word address 0 and 1. I've coped them below:
Offset R/W Width (Bits) Description
0 W 32 - Bit 0—Trigger reconfiguration.
- Bit 1—Reset the watchdog timer.
- Bit 31:2—Reserved.
1 W 32 - Bit 0—Trigger config_sel_overwrite value to the input register.
- 0: Disable overwrite config_sel pin.
- 1: Enable overwrite config_sel pin.
- Bit 1—Writes config_sel value to the input register. Set 0 or 1 to load from configuration image 0 or 1 respectively
- 0: Load configuration image 0.
- 1: Load configuration image 1.
- aiedb
hii thanks for your reply , i will try to built my own fsm and see how it will work for me
- KennyT_altera
Do you have further question? If no, we shall close this thread.
- aiedb
hii you can close thanks
- KennyT_altera
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
