max10 RSU without nios
Hi Aiebd,
RSU on Max 10 has two key steps; 1) Write the new image to flash via the User Flash Memory IP (https://www.intel.com/content/www/us/en/docs/programmable/683180/18-0/on-chip-flash-core-references.html) and 2) Identifying to the configuration system what CFM to use on the next nConfig and trigger reconfiguration via the Dual Configuration IP (https://www.intel.com/content/www/us/en/docs/programmable/683865/current/dual-configuration-core-26199.html).
You could definitely use an FSM to do these operations. I hope these user guides help give you the info you need.
- aiedb1 year ago
hii thanks a lot for help
lets say i want to write my own fsm to trigger an rsu after writing my image to cfm0 and cfm 1/2 what are the registers that i need to work with in order to :
1- trigger the nconfig ?
2-to choose from which cfm that fpga get configured ?
