max10 remote system update nios with uart
hii
i am trying to follow the application note to build a system to do a remote update of max10 over uart with nios 2
i built the qsys system with the on chip flash in order to store a factory and application rpd files
i attached the image of the on chip flash configuration i configured it as a dual compressed image in order for the cfm sections to be available to store the files
in the internal configuration under assignments-> device ->devices and pins -> configuration
i choose dual compress image the same as on chip flash configuration
also here i attached the image of my configuration
but when i compile the design i get this error
Current Internal Configuration mode does not support memory initialization or ROM.
Select Internal Configuration mode with ERAM
that does not make sense to me cause i am using dual compressed image , i be glad for help or to see if i made a mistake in my configurations
- BoonBengT_Altera
Moderator
Hi @aiedb,
As previous clarificcation has been attended, with no further clarification on this thread, it will be transitioned to community support for further help on doubts in this thread.
Please login to ‘ https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Thank you for the questions and as always pleasure having you here.
Best Wishes
BB
- sstrell
What's your target device? 10M02 does not support this (only has CFM0).
- FvM
I see that the target device is 10M50DA, thus it is supporting remote system upgrade with dual compressed image. But due to inherent limitation of MAX10 series, you can't have dual image and internal ROM at the same time. Respectively NIOS processor can be only booted from external SPI flash, see AN741.
Frank- aiedb
hii frank thanks for your reply i saw in example design that is published in altera store called max10_rsu that they used both on chip flash and ram memory for the nios 2
i attached the picture of the nios 2 configurations and you can see that the picture that the nios 2 reset vector memory is configured to be generic quad spi controller and the exception vector memory is on chip memory
and if i understand you correctly i only need qspi as a memory for nios 2 ? so what do i need to do ? i built my system according to the altera example
1-do i need to set the exception vector also to generic quad spi controller also? and remove the on chip memory from my system
i be glad for help ?
