max10 remote system update nios with uart
What's your target device? 10M02 does not support this (only has CFM0).
I see that the target device is 10M50DA, thus it is supporting remote system upgrade with dual compressed image. But due to inherent limitation of MAX10 series, you can't have dual image and internal ROM at the same time. Respectively NIOS processor can be only booted from external SPI flash, see AN741.
Frank
- sstrell1 year ago
Ah, missed that on the error screenshot.
- aiedb1 year ago
hii frank thanks for your reply i saw in example design that is published in altera store called max10_rsu that they used both on chip flash and ram memory for the nios 2
i attached the picture of the nios 2 configurations and you can see that the picture that the nios 2 reset vector memory is configured to be generic quad spi controller and the exception vector memory is on chip memory
and if i understand you correctly i only need qspi as a memory for nios 2 ? so what do i need to do ? i built my system according to the altera example
1-do i need to set the exception vector also to generic quad spi controller also? and remove the on chip memory from my system
i be glad for help ?
- Sparrow_Altera1 year ago
Hello
Can you check your design settings in Quartus with the example design settings, the link below provides the file for the example that you are trying to follow
- aiedb1 year ago
hii when i compile this project i get errors due to licince issues how can i solve it ?
