20 years agoLwIP doens't work with NIOS II 6.0
Hi all,
I've a Standalone LwIP project (download from topic "Tested IP") with NIOS II & QUARTUS 5.1. I've been testing this project with NIOS II & QUARTUS 6.0 and i've got a lot of problems and I couldn't build my project. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif It's related with LAN91C111 code, that can't be reached. I couldn't solve this problem, but if someone got it, please answer this topic. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/rolleyes.gif Next, the errors I founded. Thanks, Nosima **** Incremental build of configuration Debug for project lwip_web_server_0 **** make -s all Compiling echo.c... Compiling fs.c... Compiling fsdata.c... Compiling httpd.c... Compiling dhcp.c... ../lwip-0.7.1/src/core/dhcp.c:1395: warning: 'dhcp_get_option_short' defined but not used Compiling inet.c... Compiling icmp.c... Compiling ip.c... Compiling ip_addr.c... Compiling ip_frag.c... Compiling mem.c... Compiling memp.c... Compiling netif.c... Compiling pbuf.c... Compiling raw.c... Compiling stats.c... Compiling sys.c... Compiling tcp.c... Compiling tcp_in.c... Compiling tcp_out.c... Compiling udp.c... Compiling etharp.c... Compiling loopif.c... ../lwip-0.7.1/src/netif/loopif.c:48: warning: 'loopif_input' defined but not used Compiling lib.c... Compiling lwip_init.c... Compiling lan91c111if.c... ../lwip4hal/netif/lan91c111if.c: In function `low_level_output': ../lwip4hal/netif/lan91c111if.c:76: error: `alt_avalon_lan91c111_if' undeclared (first use in this function) ../lwip4hal/netif/lan91c111if.c:76: error: (Each undeclared identifier is reported only once ../lwip4hal/netif/lan91c111if.c:76: error: for each function it appears in.) ../lwip4hal/netif/lan91c111if.c:76: error: `dev' undeclared (first use in this function) ../lwip4hal/netif/lan91c111if.c: In function `low_level_input': ../lwip4hal/netif/lan91c111if.c:185: error: `alt_avalon_lan91c111_if' undeclared (first use in this function) ../lwip4hal/netif/lan91c111if.c:185: error: `dev' undeclared (first use in this function) ../lwip4hal/netif/lan91c111if.c:194: warning: use of cast expressions as lvalues is deprecated ../lwip4hal/netif/lan91c111if.c: In function `lan91c111if_service': ../lwip4hal/netif/lan91c111if.c:276: error: `alt_avalon_lan91c111_if' undeclared (first use in this function) ../lwip4hal/netif/lan91c111if.c:276: error: `dev' undeclared (first use in this function) ../lwip4hal/netif/lan91c111if.c:276: error: parse error before ')' token ../lwip4hal/netif/lan91c111if.c: In function `low_level_init': ../lwip4hal/netif/lan91c111if.c:303: error: `alt_avalon_lan91c111_if' undeclared (first use in this function) ../lwip4hal/netif/lan91c111if.c:303: error: `dev' undeclared (first use in this function) ../lwip4hal/netif/lan91c111if.c:303: error: parse error before ')' token ../lwip4hal/netif/lan91c111if.c:311: warning: implicit declaration of function `read_mac_address' make: *** [obj/lwip4hal/netif/lan91c111if.o] Error 1 Build completed11 Replies
You'd probably have success if you created a new project in the 6.0 IDE and imported your files from your old project. There's no guarantee that tranference of projects between versions will work...
Once you've created your new project, and copied your files over, you'll want to ensure that your include paths are set correctly... Go under the C/C++ project settings to look for this. Best of luck! - slacker - Altera_Forum
Thanks for the answer Slacker,
I did that before. Beyond, I recreated my project from beginning in Quartus II 6.0, after I started an C/C++ Project in NIOS II 6.0 with template of Lwip Web Server and I got that error. I verified paths and other settings. I think the problem is something related to include file "altera_avalon_lan91c111.h", because all functions from error come from this file. Other thing I forgot so say is that NIOS II 6.0 point this error to file "lan91c111if.c" Thanks for the advice, Best regards, Nosima --- Quote Start --- originally posted by slacker@May 22 2006, 06:24 PM you'd probably have success if you created a new project in the 6.0 ide and imported your files from your old project. there's no guarantee that tranference of projects between versions will work...once you've created your new project, and copied your files over, you'll want to ensure that your include paths are set correctly... go under the c/c++ project settings to look for this.
best of luck!
- slacker
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15510)
--- quote end ---
--- Quote End ---
Nosima
Did you ever get this working. I have hit the same problem and would be very grateful if you have any help. - Dyson --- Quote Start --- originally posted by nosima@May 22 2006, 09:40 PM thanks for the answer slacker,i did that before. beyond, i recreated my project from beginning in quartus ii 6.0, after i started an c/c++ project in nios ii 6.0 with template of lwip web server and i got that error.
i verified paths and other settings.
i think the problem is something related to include file "altera_avalon_lan91c111.h", because all functions from error come from this file.
other thing i forgot so say is that nios ii 6.0 point this error to file "lan91c111if.c"
thanks for the advice,
best regards,
nosima
--- quote start ---
originally posted by slacker@may 22 2006, 06:24 pm
You'd probably have success if you created a new project in the 6.0 IDE and imported your files from your old project. There's no guarantee that tranference of projects between versions will work... Once you've created your new project, and copied your files over, you'll want to ensure that your include paths are set correctly... Go under the C/C++ project settings to look for this. Best of luck! - slacker <div align='right'><{post_snapback}> (index.php?act=findpost&pid=15510) --- Quote End --- [/b] --- Quote End --- <div align='right'><{post_snapback}> (index.php?act=findpost&pid=15511)</div> [/b] --- Quote End ---
Hi Dyson...
I've been trying to get it work but I got no results. I don't know what to do anymore... it's really sad... I will keep trying to get it up... Best regards, Nosima --- Quote Start --- originally posted by dyson+jun 5 2006, 09:06 am--><div class='quotetop'>quote (dyson @ jun 5 2006, 09:06 am)</div>--- quote start ---
nosima
did you ever get this working. i have hit the same problem and would be
- dyson
<!--quotebegin-nosima@May 22 2006, 09:40 PM thanks for the answer slacker,
best regards,
nosima
--- quote start ---
You'd probably have success if you created a new project in the 6.0 IDE and imported your files from your old project. There's no guarantee that tranference of projects between versions will work... Once you've created your new project, and copied your files over, you'll want to ensure that your include paths are set correctly... Go under the C/C++ project settings to look for this. Best of luck! - slacker <div align='right'><{post_snapback}> (index.php?act=findpost&pid=15510) --- Quote End --- [/b] --- Quote End --- <div align='right'><{post_snapback}> (index.php?act=findpost&pid=15511)</div> [/b] --- Quote End --- <div align='right'><{post_snapback}> (index.php?act=findpost&pid=15912)</div> [/b] --- Quote End ---
TO_BE_DONE
If I copy the LWIP components\altera_avalon_lan91c111\HAL to C:\altera\quartus60\sopc_builder\components\altera_avalon_lan91c111\HAL I can build the project, but it doesn't run. Not really sure at this point what the problem is.
--Jordan - Altera_Forum
Hey...
I'm not getting any succesful result... I have been trying but no results. I tryied everything you did above, but I found same problems... I think there is a problems int the sys library... something that I see that the nios 5.1 project system library is diferent... That's all --- Quote Start --- originally posted by yek401@Jun 28 2006, 03:45 PM if i copy the lwip components\altera_avalon_lan91c111\hal to c:\altera\quartus60\sopc_builder\components\altera_avalon_lan91c111\hal i can build the project, but it doesn't run. not really sure at this point what the problem is.--jordan
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16477)
--- quote end ---
--- Quote End ---
I've succesfully made it working on NIOS 6.0 by replacing the file
C:\altera\quartus60\sopc_builder\components\altera_avalon_lan91c111\HAL\inc\altera_avalon_lan91c111.h by the one found in the archive. good luck ! - Altera_Forum
--- Quote Start --- originally posted by gjoli@Oct 5 2006, 02:51 PM i've succesfully made it working on nios 6.0 by replacing the filec:\altera\quartus60\sopc_builder\components\altera_avalon_lan91c111\hal\inc\altera_avalon_lan91c111.h
good luck !
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=18560)
--- quote end ---
--- Quote End --- Where is this archive exectly? Can you attach the good file? O.K. I found my problem at last - I moved the project to seperate workspace from old projects' workspace, and delete the backup of the old altera_avalon_lan91c111 from components folder. Now the application is working. Still look for how to change IP Address.
Hi Everyone!
As I said, LwIP will not work moreover. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif They said that they will use now NicheStack. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/dry.gif This way, we will need to pay to develop the new system. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif look this document: http://www.altera.com/literature/hb/nios2/n2sw_nii52009.pdf (http://www.altera.com/literature/hb/nios2/n2sw_nii52009.pdf) See all! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/cool.gif
