20 years agoLwIP doens't work with NIOS II 6.0
Hi all, I've a Standalone LwIP project (download from topic "Tested IP") with NIOS II & QUARTUS 5.1. I've been testing this project with NIOS II & QUARTUS 6.0 and i've got a lot of ...
20 years agoHi Dyson...
I've been trying to get it work but I got no results. I don't know what to do anymore... it's really sad... I will keep trying to get it up... Best regards, Nosima --- Quote Start --- originally posted by dyson+jun 5 2006, 09:06 am--><div class='quotetop'>quote (dyson @ jun 5 2006, 09:06 am)</div>--- quote start ---
nosima
did you ever get this working. i have hit the same problem and would be
very grateful if you have any help.
- dyson
<!--quotebegin-nosima@May 22 2006, 09:40 PM thanks for the answer slacker,
i did that before. beyond, i recreated my project from beginning in quartus ii 6.0, after i started an c/c++ project in nios ii 6.0 with template of lwip web server and i got that error.
i verified paths and other settings.
i think the problem is something related to include file "altera_avalon_lan91c111.h", because all functions from error come from this file.
other thing i forgot so say is that nios ii 6.0 point this error to file "lan91c111if.c"
thanks for the advice,
best regards,
nosima
--- quote start ---
originally posted by slacker@may 22 2006, 06:24 pm
You'd probably have success if you created a new project in the 6.0 IDE and imported your files from your old project. There's no guarantee that tranference of projects between versions will work... Once you've created your new project, and copied your files over, you'll want to ensure that your include paths are set correctly... Go under the C/C++ project settings to look for this. Best of luck! - slacker <div align='right'><{post_snapback}> (index.php?act=findpost&pid=15510) --- Quote End --- [/b] --- Quote End --- <div align='right'><{post_snapback}> (index.php?act=findpost&pid=15511)</div> [/b] --- Quote End --- <div align='right'><{post_snapback}> (index.php?act=findpost&pid=15912)</div> [/b] --- Quote End ---
