11 years agoLoading preloader image to QSPI Flash for Booting
I would like to request support for another issue on loading the QSPI flash memory of the Cyclone V SoC. As provided in the an709 document guide, the command for loading the QSPI flash is: quartus_hps -c 1 -o PV -a 0x0 preloader-mkpimage.bin Execution of this command results in: info:******************************************************************* info: running quartus ii 64-bit programmer info: version 14.1.0 build 186 12/03/2014 sj full version info: copyright (c) 1991-2014 altera corporation. all rights reserved. info: your use of altera corporation's design tools, logic functions info: and other software and tools, and its ampp partner logic info: functions, and any output files from any of the foregoing info: (including device programming or simulation files), and any info: associated documentation or information are expressly subject info: to the terms and conditions of the altera program license info: subscription agreement, the altera quartus ii license agreement, info: the altera megacore function license agreement, or other info: applicable license agreement, including, without limitation, info: that your use is for the sole purpose of programming logic info: devices manufactured by altera and sold by altera or its info: authorized distributors. please refer to the applicable info: agreement for further details. info: processing started: tue may 12 12:06:19 2015 info: command: quartus_hps -c 1 -o pv -a 0x0 preloader-mkpimage.bin current hardware is: cv sockit [usb-1] found hps at device 2 hps device idcode: 0x4ba00477 ahb port is located at port 0 apb port is located at port 1 boot info: 3.0v qspi flash clock select: 0 double aji delay - 1024 tcks start hps quad spi flash programming ... initialize qspi peripheral and flash controller ... read silicon id of quad spi flash ... error: fail to poll the qspi command execution status error: fail to read silicon id error: quartus ii 64-bit programmer was unsuccessful. 0 errors, 0 warnings error: peak virtual memory: 115 megabytes error: processing ended: tue may 12 12:06:20 2015 error: elapsed time: 00:00:01 error: total cpu time (on all processors): 00:00:00 I have enabled the QSPI flash controller in the HPS peripheral list. I built the preloader by selecting BOOT_FROM_QSPI option in the bsp-editor and further issuing "make" command in the spl_bsp directory. Please advise on this issue. Thanks in advance. Regards, Nitin.2 Replies
Not sure if this helps, Below is a section of output when I program which might give you a clue to the cause.
Info: Processing started: Mon Sep 01 15:59:39 2014 Info: Command: quartus_hps -c 1 -o P preloader-mkpimage.bin Current hardware is: Helio [USB-1] Found HPS at device 1 HPS Device IDCODE: 0x4BA00477 AHB Port is located at port 0 APB Port is located at port 1 Boot Info: 3.0V QSPI Flash Start HPS Quad SPI flash programming ... Initialize QSPI peripheral and flash controller ... Read Silicon ID of Quad SPI flash ... Quad SPI Flash silicon ID is 0x1020BA20 Flash device matched Manufacturer: Micron Device: QSPI_512 Enable Four Byte Addressing ... Sector Erase Quad SPI flash ... Sector Erase Info: Start Addr at 0x00000000 for 4 sector(s) Sector Erase Quad SPI flash at 0x00000000 Sector Erase Quad SPI flash at 0x00010000 Sector Erase Quad SPI flash at 0x00020000 Sector Erase Quad SPI flash at 0x00030000 Program Quad SPI flash ... Info: Quartus II 64-Bit Programmer was successful. 0 errors, 0 warnings Info: Peak virtual memory: 126 megabytes Info: Processing ended: Mon Sep 01 16:00:17 2014 Info: Elapsed time: 00:00:38 Info: Total CPU time (on all processors): 00:00:05 - Altera_Forum
sound like Quad spi access also failed.
may want to have a try on the general version from http://rocketboards.org/foswiki/view/documentation/gsrd131qspiboot
