11 years agoLoading preloader image to QSPI Flash for Booting
Hi, I would like to request support for another issue on loading the QSPI flash memory of the Cyclone V SoC. As provided in the an709 document guide, the command for loading the QSPI flash is:...
11 years agoNot sure if this helps, Below is a section of output when I program which might give you a clue to the cause.
Info: Processing started: Mon Sep 01 15:59:39 2014 Info: Command: quartus_hps -c 1 -o P preloader-mkpimage.bin Current hardware is: Helio [USB-1] Found HPS at device 1 HPS Device IDCODE: 0x4BA00477 AHB Port is located at port 0 APB Port is located at port 1 Boot Info: 3.0V QSPI Flash Start HPS Quad SPI flash programming ... Initialize QSPI peripheral and flash controller ... Read Silicon ID of Quad SPI flash ... Quad SPI Flash silicon ID is 0x1020BA20 Flash device matched Manufacturer: Micron Device: QSPI_512 Enable Four Byte Addressing ... Sector Erase Quad SPI flash ... Sector Erase Info: Start Addr at 0x00000000 for 4 sector(s) Sector Erase Quad SPI flash at 0x00000000 Sector Erase Quad SPI flash at 0x00010000 Sector Erase Quad SPI flash at 0x00020000 Sector Erase Quad SPI flash at 0x00030000 Program Quad SPI flash ... Info: Quartus II 64-Bit Programmer was successful. 0 errors, 0 warnings Info: Peak virtual memory: 126 megabytes Info: Processing ended: Mon Sep 01 16:00:17 2014 Info: Elapsed time: 00:00:38 Info: Total CPU time (on all processors): 00:00:05
