13 years agoLoading image to SDRAM under ubuntu
I am trying to run uclinux on DE0-Nano, and i successfully generated the zImage, but iam unable to load the image into SDRAM, it showing error like alex@alex:~$ nios2-download -g ~/uClinux/distro/nios2-linux/uClinux-dist/images/zImage /opt/nios2eds/bin/nios2-gdb-server-wrapped: error while loading shared libraries: libjtag_client.so: cannot open shared object file: no such file or directory. Where is the mistake? Thanks in advance.35 Replies
Also remember to put the quartus bin directory in your .bashrc file
alex@alex:~$ gedit ~/.bashrc & and add the following line to the bottom of the file export PATH=$PATH:/opt/quartus/bin Then log out and log back in. N. - Altera_Forum
I tried all the steps , as u mentioned in your previous post, but same problem, where is the mistake?
error there is a problem with the quartus ii installation on your computer.please use `jtagconfig` for further diagnosis. else cont we download the image into SDRAM under ubuntu? Thanks, Alex.
Sir,
If i open my bashrc file its showing error like this, previosuly i opend ,but at that time i dint get any error, but now.... alex@alex:~$ gedit ~/.bashrc /opt/quartus/linux/libstdc++.so.6: version `glibcxx_3.4.11' not found (required by /usr/lib/i386-linux-gnu/libproxy.so.1)failed to load module: /usr/lib/i386-linux-gnu/gio/modules/libgiolibproxy.so
** (gedit:2404): warning **: error loading plugin: /opt/quartus/linux/libstdc++.so.6: version `glibcxx_3.4.15' not found (required by /usr/lib/libaspell.so.15)
** (gedit:2404): warning **: error loading plugin: /opt/quartus/linux/libstdc++.so.6: version `glibcxx_3.4.15' not found (required by /usr/lib/libaspell.so.15) finally my bashrc file is
# ~/.bashrc: executed by bash(1) for non-login shells.# see /usr/share/doc/bash/examples/startup-files (in the package bash-doc)# for examples # If not running interactively, don't do anything [ -z "$PS1" ] && return # don't put duplicate lines or lines starting with space in the history.# See bash(1) for more options HISTCONTROL=ignoreboth # append to the history file, don't overwrite it shopt -s histappend # for setting history length see HISTSIZE and HISTFILESIZE in bash(1) HISTSIZE=1000 HISTFILESIZE=2000 # check the window size after each command and, if necessary,# update the values of LINES and COLUMNS. shopt -s checkwinsize # If set, the pattern "**" used in a pathname expansion context will# match all files and zero or more directories and subdirectories.# shopt -s globstar # make less more friendly for non-text input files, see lesspipe(1) [ -x /usr/bin/lesspipe ] && eval "$(SHELL=/bin/sh lesspipe)" # set variable identifying the chroot you work in (used in the prompt below) if [ -z "$debian_chroot" ] && [ -r /etc/debian_chroot ]; then debian_chroot=$(cat /etc/debian_chroot) fi # set a fancy prompt (non-color, unless we know we "want" color) case "$TERM" in xterm-color) color_prompt=yes;; esac # uncomment for a colored prompt, if the terminal has the capability; turned# off by default to not distract the user: the focus in a terminal window# should be on the output of commands, not on the prompt# force_color_prompt=yes if [ -n "$force_color_prompt" ]; then if [ -x /usr/bin/tput ] && tput setaf 1 >&/dev/null; then # We have color support; assume it's compliant with Ecma-48 # (ISO/IEC-6429). (Lack of such support is extremely rare, and such # a case would tend to support setf rather than setaf.) color_prompt=yes else color_prompt= fi fi if [ "$color_prompt" = yes ]; then PS1='${debian_chroot:+($debian_chroot)}\[\033[01;32m\]\u@\h\[\033[00m\]:\[\033[01;34m\]\w\[\033[00m\]\$ ' else PS1='${debian_chroot:+($debian_chroot)}\u@\h:\w\$ ' fi unset color_prompt force_color_prompt # If this is an xterm set the title to user@host:dir case "$TERM" in xterm*|rxvt*) PS1="\[\e]0;${debian_chroot:+($debian_chroot)}\u@\h: \w\a\]$PS1" ;; *) ;; esac # enable color support of ls and also add handy aliases if [ -x /usr/bin/dircolors ]; then test -r ~/.dircolors && eval "$(dircolors -b ~/.dircolors)" || eval "$(dircolors -b)" alias ls='ls --color=auto' # alias dir='dir --color=auto' # alias vdir='vdir --color=auto' alias grep='grep --color=auto' alias fgrep='fgrep --color=auto' alias egrep='egrep --color=auto' fi # some more ls aliases alias ll='ls -alF' alias la='ls -A' alias l='ls -CF' # Add an "alert" alias for long running commands. Use like so:# sleep 10; alert alias alert='notify-send --urgency=low -i "$([ $? = 0 ] && echo terminal || echo error)" "$(history|tail -n1|sed -e '\''s/^\s*[0-9]\+\s*//;s/[;&|]\s*alert$//'\'')"' # Alias definitions.# You may want to put all your additions into a separate file like# ~/.bash_aliases, instead of adding them here directly.# See /usr/share/doc/bash-doc/examples in the bash-doc package. if [ -f ~/.bash_aliases ]; then . ~/.bash_aliases fi # enable programmable completion features (you don't need to enable# this, if it's already enabled in /etc/bash.bashrc and /etc/profile# sources /etc/bash.bashrc). if [ -f /etc/bash_completion ] && ! shopt -oq posix; then . /etc/bash_completion fi# Nios II Toolchain export PATH=$PATH:~/uClinux/Tools/opt/nios2/bin export PATH=$PATH:/opt/quartus/bin export PATH=$PATH:/opt/nios2eds/bin export PATH=$PATH:/opt/sopc_builder/bin export PATH=$PATH:/opt/nios2eds/bin/gnu/H-i686-pc-linux-gnu/bin export PATH=$PATH:/opt/quartus/bin Thanks, Alex.
Are you running an old version of quartus? Perhaps you're better of reinstalling v12.0 of Quartus II?
N. - Altera_Forum
Iam using quartus 11.1 service pack, is it ok?, otherwise i have to reinstall quartus with 12v? and one more thing i have downloaded nios2-linux-20090929.tar under windows, is any problem ?
Thanks, Alex. - Altera_Forum
Please do the following:
1. Open up a terminal and type "jtagconfig" followed by enter. What does it say? 2. Install libstdc++6 using the command "sudo apt-get install libstdc++6" N. - Altera_Forum
alex@alex:~$ jtagconfig
1) USB-Blaster variant [7-1] Unable to lock chain (Insufficient port permissions) and i installed the libstdc++6 also, and i am using ubuntu12.04 Thanks, alex. - Altera_Forum
That's exactly the kind of problem the /lib/udev/rules.d/51-usbblaster.rules file is supposed to fix.
Connect your altera device to the usb port and execute "lsusb" in a terminal. The output should contain a line like this: Bus 003 Device 002: ID 09fb:6001 Altera Blaster N. - Altera_Forum
Ya, the output is like .
alex@alex:~$ lsusb Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 001 Device 002: ID 1210:25f4 DigiTech Bus 006 Device 002: ID 15d9:0a4c Trust International B.V. USB+PS/2 Optical Mouse Bus 007 Device 004: ID 09fb:6001 Altera Blaster then how to fix the problem? - Altera_Forum
Are you sure you installed the rules file correctly?
Type in "cat /lib/udev/rules.d/51-usbblaster.rules" at the command prompt. It should say: ATTR{idVendor}=="09fb", ATTR{idProduct}=="6001", MODE="666" You did reboot your machine, right? N.
