14 years agoLoading image to SDRAM under ubuntu
Hi, I am trying to run uclinux on DE0-Nano, and i successfully generated the zImage, but iam unable to load the image into SDRAM, it showing error like alex@alex:~$ nios2-download -g ~/...
14 years agoAre you sure you installed the rules file correctly?
Type in "cat /lib/udev/rules.d/51-usbblaster.rules" at the command prompt. It should say: ATTR{idVendor}=="09fb", ATTR{idProduct}=="6001", MODE="666" You did reboot your machine, right? N.
