20 years agoload application uclinux on NIOS IDE to board ???
Hi All
(sorry my English) I just start on uClinux . I try load application (example hello in C:\altera\kits\nios2_60\examples\software\linux\apps\samples\hello ) on board . framework is nios ide window . - the first I build kernel that is all right. - I build filesystem all right . - after that I build application (hello) and generate hello.exe + hello.gdb and copy it to project filesystem and rebuild filesystem generate "romfs.bin" I load .sof and kernel on board but i can't load filesystem and application . everybody help me the way to load filesystem + application on board thanks. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif10 Replies
what exactly went wrong?
Hi !
thanks for Reply . I did step by step by liux Quick start Guide + linux reference guide after I login + password ..... but I can't find application .... http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif - Altera_Forum
<div class='quotetop'>QUOTE </div>
--- Quote Start --- I load .sof and kernel on board but i can't load filesystem and application[/b] --- Quote End --- so your linux is running ok. where did you put your application in your filesystem-project? - Altera_Forum
--- Quote Start --- originally posted by helmchen@Oct 17 2006, 04:10 AM <div class='quotetop'>quote--- quote end ---
--- quote start ---
i load .sof and kernel on board but i can't load filesystem and application --- Quote End --- so your linux is running ok. where did you put your application in your filesystem-project? <div align='right'><{post_snapback}> (index.php?act=findpost&pid=18742)</div> [/b] --- Quote End --- Hi Helmchen ! my linux is running ok . I put my application in /home of filesystem project . thanks
silly question, did rebuild your kernel?
Can you put your application again in your filesystem, rebuild and upload it. just to be sure. this time please put copy in the bin directory (just for a test) - Altera_Forum
thanks
I will try !!!!! - Altera_Forum
--- Quote Start --- silly question, did rebuild your kernel?[/b] --- Quote End --- filesystem not kernel!! - Altera_Forum
Hi !
I have tried but not progress ! I think manual linux quick start Guide and linux reference Guide is Cursory so I think i just load kernel on board and no filesystem and application . who can help me step by step to load filesystem and application or document about that thank very much . http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif - Altera_Forum
--- Quote Start --- Hi ! I have tried but not progress ! I think manual linux quick start Guide and linux reference Guide is Cursory so I think i just load kernel on board and no filesystem and application . who can help me step by step to load filesystem and application or document about that[/b] --- Quote End --- If you only upload your kernel, you couldn't be able to login. <div class='quotetop'>QUOTE </div> --- Quote Start --- after I login + password ..... but I can't find application ....[/b] --- Quote End --- Now i'm really confused. Without any precise information i just can advice you to use the search function. You can find the information in minutes instead of waiting for hours to get an anwser. - Altera_Forum
--- Quote Start --- originally posted by vietluong@Oct 17 2006, 03:50 AM hi all(sorry my english)
i just start on uclinux .
i try load application (example hello in c:\altera\kits\nios2_60\examples\software\linux\apps\samples\hello ) on board . framework is NIOS IDE window .[/b] - the first I build kernel that is all right. - I build filesystem all right . - after that I build application (hello) and generate hello.exe + hello.gdb and copy it to project filesystem and rebuild filesystem generate "romfs.bin" I load .sof and kernel on board but i can't load filesystem and application . everybody help me the way to load filesystem + application on board thanks. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif <div align='right'><{post_snapback}> (index.php?act=findpost&pid=18739) --- Quote End --- [/b] --- Quote End --- Silly question, did you upload the romfs.bin onto the target?
