20 years agoload application uclinux on NIOS IDE to board ???
Hi All (sorry my English) I just start on uClinux . I try load application (example hello in C:\altera\kits\nios2_60\examples\software\linux\apps\samples\hello ) on board . framework is...
19 years ago --- Quote Start --- originally posted by vietluong@Oct 17 2006, 03:50 AM hi all
(sorry my english)
i just start on uclinux .
i try load application (example hello in c:\altera\kits\nios2_60\examples\software\linux\apps\samples\hello ) on board . framework is NIOS IDE window .[/b] - the first I build kernel that is all right. - I build filesystem all right . - after that I build application (hello) and generate hello.exe + hello.gdb and copy it to project filesystem and rebuild filesystem generate "romfs.bin" I load .sof and kernel on board but i can't load filesystem and application . everybody help me the way to load filesystem + application on board thanks. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif <div align='right'><{post_snapback}> (index.php?act=findpost&pid=18739) --- Quote End --- [/b] --- Quote End --- Silly question, did you upload the romfs.bin onto the target?
