20 years agoLiterature about embedded Linux
Hi Friends!
I'm a beginner in using embedded Linux and so I'm looking for a literature about embedded Linux. The main issues in such a book should be: -Develop software (device driver, applications) for eL. -Kernel modification. -Booting eL. -Debugging on eL. -Real-world interfacing with eL. -Root filesystem creation. -Using serial, parallel, memory I/O, USB, graphic displays and interrupt-driven hardware. A book like this is "Embedded Linux" written by Craig Hollabaugh. But it's include only x86, StrongARM and PowerPC as examples of platforms, not Nios. Should I make the compromise to buy it or does somebody knows a better book? Bye, Lothar.2 Replies
--- Quote Start --- originally posted by maico+dec 1 2005, 10:43 am--><div class='quotetop'>quote (maico @ dec 1 2005, 10:43 am)</div>--- quote start ---
i'm a beginner in using embedded linux and so i'm looking for a literature about embedded linux.
the main issues in such a book should be:
-develop software (device driver, applications) for el.[/b]
--- quote end ---
the autobook for user level applications (gnu/autotools). can be read on the net or bought on e.g. amazon.
--- quote start ---
originally posted by maico@dec 1 2005, 10:43 am
-kernel modification.
--- quote end ---
o'reilly has 2 good books about this one; one about the kernel and one about device drivers; check their site or amazon
--- quote start ---
-booting el.
--- quote end ---
e.g. wolfgang denk's das u-boot; he maintains a good portion of documentation on his bootloader.
--- quote start ---
-debugging on el.
--- quote end ---
several resources, mainly running on gdb (ddd). i guess you'll find the most documentation about this on the net.
--- quote start ---
-real-world interfacing with el.
-root filesystem creation.
--- quote end ---
depends on what you're doing; but checking buildroot might be a good start; for a nios fs, you need little more than the basic directory structure and the device nodes (you should not use devfs, since it's being ripped out in the later kernels).
--- quote start ---
-using serial, parallel, memory i/o, usb, graphic displays and interrupt-driven hardware.
--- quote end ---
check the o'reilly books...
<!--quotebegin-maico@Dec 1 2005, 10:43 AM a book like this is "embedded linux" written by craig hollabaugh. --- Quote End --- I think O'Reilly has one titled 'embedded systems'; a very good book. --- Quote Start --- originally posted by maico@Dec 1 2005, 10:43 AM but it's include only x86, strongarm and powerpc as examples of platforms, not nios.
should i make the compromise to buy it or
does somebody knows a better book? --- Quote End --- I don't think you'll find better resources on Nios II; since it is not, and will likely never be, a very wide spread and accepted solution for (uC)Linux; Altera ppl actually say this in between the lines.
Hello Marc!
Thank you, for your detailed answer. I've bought "Linux Devices Drivers" and "Building Embedded Linux Systems" from O'Reilly. I will check your other hints too. At the moment I'm intensely working with "Linux Devices Drivers". <div class='quotetop'>QUOTE </div> --- Quote Start --- I don't think you'll find better resources on Nios II; since it is not, and will likely never be, a very wide spread and accepted solution for (uC)Linux; Altera ppl actually say this in between the lines.[/b] --- Quote End --- Do Altera mention any reason why Nios II will probably never be a very wide spread and accepted solution for µLinux? Bye, Lothar.
