20 years agoLiterature about embedded Linux
Hi Friends! I'm a beginner in using embedded Linux and so I'm looking for a literature about embedded Linux. The main issues in such a book should be: -Develop software (device d...
20 years agoHello Marc!
Thank you, for your detailed answer. I've bought "Linux Devices Drivers" and "Building Embedded Linux Systems" from O'Reilly. I will check your other hints too. At the moment I'm intensely working with "Linux Devices Drivers". <div class='quotetop'>QUOTE </div> --- Quote Start --- I don't think you'll find better resources on Nios II; since it is not, and will likely never be, a very wide spread and accepted solution for (uC)Linux; Altera ppl actually say this in between the lines.[/b] --- Quote End --- Do Altera mention any reason why Nios II will probably never be a very wide spread and accepted solution for µLinux? Bye, Lothar.
