17 years agolinux:make error
i fellow http://www.nioswiki.com/linux (http://www.nioswiki.com/linux)
when i input make command,it came to a error as bellow; make[2]: Entering directory `/mywork/nios2-linux/uClinux-dist/vendors/Altera/nios2' set -e; t=`nios2-wrs-linux-gnu-gcc -mhw-mul -mno-hw-mulx -print-file-name=libc.a`; t=`dirname $t`/../..; for i in $t/lib/*so*; do i=`readlink -f "$i"`; soname=`nios2-wrs-linux-gnu-readelf -d "$i" | sed -n '/(SONAME)/s:.*[[]\(.*\)[]].*:\1:p'`; if [ ! -f "/mywork/nios2-linux/uClinux-dist/romfs/lib/$soname" ] ; then romfs-inst.sh -d -p 755 $i /lib/$soname; fi; done; if [ "y" = "y" ] ; then /mywork/nios2-linux/uClinux-dist/vendors/AnalogDevices/trim-libs.sh; fi; if type nios2-wrs-linux-gnu-ldconfig >/dev/null 2>&1; then nios2-wrs-linux-gnu-ldconfig -r /mywork/nios2-linux/uClinux-dist/romfs; fi /mywork/nios2-linux/uClinux-dist/vendors/AnalogDevices/trim-libs.sh: line 19: scanelf: command not found ERROR: you do not have pax-utils installed make[2]: *** [romfs.shared.libs] 错误 1 make[2]: Leaving directory `/mywork/nios2-linux/uClinux-dist/vendors/Altera/nios2' make[1]: *** [romfs.post] 错误 2 make[1]: Leaving directory `/mywork/nios2-linux/uClinux-dist/vendors' why it happenedd,and how can i deal with it??4 Replies
Install pax-utils :-) Seriously, find out how to install the pax-utils program on your system. Most Linux distros even have a GUI for this, these days.
Cheers, - slacker - Altera_Forum
<div class='quotetop'>QUOTE (slacker @ Sep 4 2009, 11:43 AM) <{post_snapback}> (index.php?act=findpost&pid=23750)</div>
--- Quote Start --- Install pax-utils :-) Seriously, find out how to install the pax-utils program on your system. Most Linux distros even have a GUI for this, these days. Cheers, - slacker[/b] --- Quote End --- ths,slacker i have installed paxutils-2.4h,below is how i installed tar xfz paxutils-2.4h.tar.gz cd paxutils-2.4h ./configure make && make check make install DESTDIR=/usr/src/paxutils-2.4h/.inst but the ERROR: you do not have pax-utils installed still not removed, is the paxutils version wrong?? or any other reason?? thanks.. - Altera_Forum
thks,slacker
i have removed the error after installing pax-utils - Altera_Forum
can you tell me that how did you solve the problem ?
I have the very same problem. thanks! --- Quote Start --- <div class='quotetop'>QUOTE (slacker @ Sep 4 2009, 11:43 AM) <{post_snapback}> (http://index.php?act=findpost&pid=23750)</div> ths,slacker i have installed paxutils-2.4h,below is how i installed tar xfz paxutils-2.4h.tar.gz cd paxutils-2.4h ./configure make && make check make install DESTDIR=/usr/src/paxutils-2.4h/.inst but the ERROR: you do not have pax-utils installed still not removed, is the paxutils version wrong?? or any other reason?? thanks.. --- Quote End ---
