17 years agolinux:make error
i fellow http://www.nioswiki.com/linux (http://www.nioswiki.com/linux) when i input make command,it came to a error as bellow; make[2]: Entering directory `/mywork/nios2-linux/uClinux-dist/ve...
16 years agocan you tell me that how did you solve the problem ?
I have the very same problem. thanks! --- Quote Start --- <div class='quotetop'>QUOTE (slacker @ Sep 4 2009, 11:43 AM) <{post_snapback}> (http://index.php?act=findpost&pid=23750)</div> ths,slacker i have installed paxutils-2.4h,below is how i installed tar xfz paxutils-2.4h.tar.gz cd paxutils-2.4h ./configure make && make check make install DESTDIR=/usr/src/paxutils-2.4h/.inst but the ERROR: you do not have pax-utils installed still not removed, is the paxutils version wrong?? or any other reason?? thanks.. --- Quote End ---
